3-Newcomer
Sep 12, 2025 6:26 PM UTC
We need to change the default Apache ports in our Windchill PDMLink 10.2 environment from 80 to 443
I am using Windchill PDS - Internal Site Release 10.2 and Datecode with CPS N/A
We need to change the default Apache ports in our Windchill PDMLink 10.2 environment. Currently, Apache is running on the default ports (80 for HTTP and 443 for HTTPS). Please provide guidance and best practices on which configuration files and Windchill settings must be updated, as well as the recommended validation steps after the change.
I would also like to schedule a call with PTC Support to go over this issue in detail and ensure the port change is implemented correctly without downtime or impact to integrations. Please let me know available times for a session.
avillanueva
23-Emerald II
Sep 12, 2025 6:47 PM UTC
https://www.ptc.com/en/support/article/CS23827?source=search
This is what you are looking for. Note that this is NOT a tech support site for PTC where you can have a collaboration session. These are other Windchill customers (and some PTC folks) that are replying to your posts. Please use a PTC tech support ticket (https://www.ptc.com/en/support) if you want direct support.
avillanueva
23-Emerald II
Community Moderator
Sep 24, 2025 9:50 PM UTC
Hi @YB_13961147,
Anurag
