webject authorization
  • April 6, 2011
  • 2 replies
  • 621 views
Hi all,
after browsing through manuals and code examples I did not found the solution for my problem, so I'm asking if anybody can point me to the right direction to solve my problem. I created several jsp pages that retrieve data from the windchill, i have to run them without the use of web browsers and even do I put DBUSER and PASSWD in the webject I am still asked for username and password. What am I missing here?
Thanks in advance!
code snipet:
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE"" data="&lt;%=wtInstance%">" default="lan.wctserver.Windchill"/>
<ie:param name="DBUSER"" data="wcadmin"/">
<ie:param name="PASSWD"" data="wcadmin"/">
<ie:param name="OBJECT_REF"" data="&lt;%=obid%">"/>
<ie:param name="TYPE"" data="&lt;%=aClass%">"/>
<ie:param name="ATTRIBUTE"" data="obid,name,number" delim=","/">
<ie:param name="ATTRIBUTE"" data="containerReference,iterationInfo.creator" delim=","/">
<ie:param name="GROUP_OUT"" data="grpout"/">
</ie:webject>
i tried also:
<ie:param name="DBUSER"" data="uid=wcadmin,ou=people,cn=AdministrativeLdap,cn=Windchill_10.0,o=ptc"/">
</ie:webject>
3-Newcomer
April 6, 2011
In order to avoid the login screen for basic authentication the username/password need to be base64 encrypted and included in the header of the GET/POST request..
Ok, I understed.
Thanks for the input Ross.
Best regards!
