7-Bedrock
Aug 13, 2014 12:52 PM UTC
WGM with Inventor: how to map custom parameters from Inventor to Windchill if the parameter contains a special character like a spacing
I'm investigating the use of the WGM with Inventor.
The Inventor files carry a number of custom parameters of which some have a parameter name that contains a blank space, e.g. 'Treatment process"
Problem now is how to define a Windchill attribute (in version 10.2) so I can capture the value of this parameter.
Any parameter that has a name which does not carry a special character and so complies to the rules of Windchill attribute definition can be captured easily (either implicitly or explicitly).
7-Bedrock
Aug 14, 2014 9:32 AM UTC
After retesting it seems it does work by explicit attribute mapping after all.
The internal IBA name in Windchill cannot contain any special characters like blanks, but when using explicit mapping for an authoring application (in this case Inventor) and entering the proper (case-sensitive) name of the targeted parameter, after checking-in the Inventor file, the parameter value is properly propagated into the IBA.
jvankoetsem7-BedrockAuthorAnswer
7-Bedrock
BenPerry
Apr 28, 2015 4:14 PM UTC
Jan Van Koetsem,
Can you show an example screenshot in Type/Attribute Manager. We are looking at putting Inventor files into our Windchill instance. A quick screenshot might be sufficient to get me started without having to "open the book". Thanks!
7-Bedrock
Apr 30, 2015 1:16 PM UTC
Hi Ben,
In type & attribute manager, add an attribute to the CAD type as normal. Once added (and still in edit mode) select the newly added attribute and in the top-right window, search for the application you want to connect with (in this case Autodesk Inventor). In the field next to the application's label, enter the name of the attribute as defined in the application.
After a "save" and "done you're set to go
