Where to get Info*Engine help?
  • May 12, 2010
  • 5317 views
we are undertaking some in-house development of some task delegates to access Windchill from the Info*Engine. Beyond the PDFs and JavaDocs, is there some tutorials or a forum that addresses using the WindchillAdapter for basic tasks like creating a folder, etc?
Are you talking about the PDFs for Info*Engine and accompanying technology? Or other PDFs? These may (or may not) be helpful:
See PTC's course TRN-2144-T or TRN-2136-T
These doc's are in PTC's knowledgebase as "suggested Techniques":
http://www.ptc.com/appserver/cs/search/search.jsp?&q=Info*Engine&mode=simpleall&nav=ptcdoctype%7C%7CHowTo%7C%7CDocument+Type%7C%7CSuggested+Technique
PDF's for the adapters (Windchill Adapter Guide in here):
http://www.ptc.com/appserver/cs/doc/refdoc.jsp?p=browse_results&Product=Windchill+InfoEngine+Adapters&Release=&DocType=&Role=
PDF's for Info*Engine Server:
http://www.ptc.com/appserver/cs/doc/refdoc.jsp?p=browse_results&Product=Windchill+InfoEngine+Server&Release=&DocType=&Role=
More:
http://www.ptc.com/appserver/cs/search/search.jsp?&q=Info*Engine&mode=simpleall&nav=ptcdoctype%7C%7C%22Reference+Document%22%7C%7CDocument+Type%7C%7CReference+Document
I found this forum:
http://www.catalyst-cs.com/forums/forum.jspa?forumID=10
I ran out of time but also google the following: +Windchill +forum
Hope this helps or maybe sparks an idea for a search that will get you there
I had the Info*Engine and Windchill Adapter PDFs, but they are a little sketchy in some places. The example tasks help a lot, and there were a few references in here I hadn't found yet. ptcuser.org is new to me, I'll be there next.
thank you.
