May 23, 2013 2:58 PM UTC
Which Browser should I use to run Windchill 10.1
I am currently testing Windchill 10.1 and getting ready for implementation. I wanted to know which browser I should use to work best with Windchill 10.1 and Java.
I use Chrome for everything but I was not sure if IE or Firefox had any advantage with Java running smoother.
ΜΟΛΩΝ ΛΑΒΕ
2-Explorer
May 23, 2013 3:57 PM UTC
PTC has released a browser comparison Technical Brief
avillanueva
23-Emerald II
May 23, 2013 4:08 PM UTC
Document is 2 years old. They should revise it.
Apr 21, 2016 8:54 AM UTC
Current version of the file is dated in June 2015:
http://www.ptc.com/WCMS/files/125513/en/WindchillWebBrowserComparisonTechBrief.pdf
May 23, 2013 8:05 PM UTC
I do appreciate the link to the document but it's so old, I can't use it to make a decision. I will stick with IE10 for now, but I was running it on Firefox and Chrome just fine.
ΜΟΛΩΝ ΛΑΒΕ
May 24, 2013 12:54 PM UTC
Damian,
We just finished our own testing with Windchill 10.1 M030. Internet Explorer 10 does not work. It constantly crashes making things difficult to say the least. We are currently using FireFox, as this was the most stable and crash free.
Hope this helps.
Brian
May 24, 2013 1:10 PM UTC
I use Chrome for Windchill 10-10.1. If I'm having to go back to WC 9, I'll use IE. I can't recall having a problem with any features using Chrome/WC10.
That being said, I still keep multiple browsers installed just in case. You can always switch to IE, FF if you find certain features do not work as well. I find it to be good practice on any web applications.
May 24, 2013 1:38 PM UTC
In Reply to Brian Clark:
Damian,
Hope this helps.
Brian
Are you using the following config command?
windows_browser_type mozilla_based_browser
I figured if you are having issues with IE that the internal browser which uses the IE Engine may give you problems as well or is this different?
Can I keep the internal browser in Creo as IE but use Firefox as the stand alone browser?
I prefer Chrome and may choose this as my stand alone option.
ΜΟΛΩΝ ΛΑΒΕ
May 28, 2013 2:26 PM UTC
We're on 10.1. Our users generally have the capability of choose which browser to use. I've seen no isues on IE9 and FF. Several use Chrome, I didn't hear of any problems until they tried to launch Creo View.
In Reply to Damian Castillo:
ΜΟΛΩΝ ΛΑΒΕ
May 29, 2013 10:34 AM UTC
Hi
I would first check what your company IT policy is. Can any user install any webbrowser ?
Could you have other systems requiring a particular version of a particular webbrowser ?
As said above by someone else. ProductView is not always compatible with other webbrowsers.
Is the fact that Chrome display certain pages more quickly than IE a good enough reason when certain functionality (maybe not often use) will not work with Chrome.
Personnally, I use Chrome only for certain tasks but I know the risk I take, sometimes windows get frozen and I tend to clear Chrome's cache a lot more often than with IE.
May 29, 2013 4:07 PM UTC
Here are the answers to these questions at Solar Turbines.
No. While many users are capable of installing their own browsers, our
technical support will not support any Browsers others than those approved
by IT. Moreover, most users do not have adequate PC permissions to
install their own browser. Our company support Internet Explorer 8.0 and
9.0, as well as Chrome (a recent addition to supported browsers, only this
year). Our Windchill support team has only tested and will therefore only
support Internet Explorer 8.0 with Google Chrome Frame (necessary for BOM
performance in Windchill 10.0) and Internet Explorer 9.0 without Google
Chrome Frame (the Chrome Frame with 9.0 had too many problems, and the
performance improvement with Chrome Frame for Internet Explorer 9.0 is not
as significant as with 8.0). We want to move users to Chrome, but we have
not had time to fully test it with all of the out of the box functions we
need, as well as with all of our reports and other site-specific
enhancements.
Yes. There are a few cases where we make exceptions for specific reasons.
In fact, there is one custom Windchill 10.1 report that displays so much
data that we force them to use the otherwise unsupported Chrome Browser
JUST FOR THAT REPORT, since that report displays minutes faster in Chrome
than IE 8 or IE 9. We have a few other applications that require some
other browser, but not very many, and it is always for reasons of
performance.
other webbrowsers.
We would never try to support all browsers. We will test a certain
configuration of browsers and support those configurations, only.
ProductView works with configurations that we support.
work with Chrome.
In general, no. However, as I mentioned above, in extreme cases (like our
massive custom report that runs many minutes faster in Chrome), we do this
just for that report and only for those very few users who use that
report. We would never try to do this for a large body of users.
Al
May 29, 2013 7:41 PM UTC
We don't restrict users from what Browser they can run or from installing applications on their workstations.
I simply want to know which browser is best for Windchill 10.1 so that I can let all my Engineers know which one to use.
I also wanted to know about the embeded Creo browser. My understanding is that it uses the IE engine. Is it OK to leave this default broswer alone? My users will mainly access Windchill through the embeded browser anyway.
ΜΟΛΩΝ ΛΑΒΕ
