Windchill 10.0 M010 Workflow window would not launch.
In 'Workflow Template Administration' window, when you try to create a new Template or edit existing one, you get the login screen but then nothing loads. You see windows 'loading' sign but no window loads for you to create or edit any workflows. I enabled Java console for message and here is what it says: (Note that all other Java applet windows for L/C Template Administration, Policy Administration, etc loads alrgiht).
basic: Applet started
basic: Told clients applet is started
I have case opened with PTC support since few days now. We tried many things together, but nothing has helped. Ad per PTC support, this Workflow issue is faced by 7 out of 10 people. And everythime, they have to try different methods to resolve it. There is no surefire way to solve it. They have contacted R&D on this.
Has any of you faced similar issue? If so, were you able to solve it? How?
Thanks in advance for your advise on this.
