Windchill 10.0M020 PSI fails with Apache failed to stop error
I am trying to update an existing Windchill 10.0M020 installation to include "Creo View" by running the PSI. PSI fails with error message Apache failed to stop..com.ptc.windchill.install.psi.InstallCommandException. Portion of the log below -
I tried by keeping Apache running/ Not running before launching PSI and also removed it from service, but gets the same error.
Httpd.exe is not runnng, I confirmed with process explorer.
http://__Fully_Qualified_Machine_Name__:80 in the browser does not show Apache running
-AJ
DEBUG 2012-02-10 01:39:27 - Product install dir is E:\ptc\PSI.
DEBUG 2012-02-10 01:39:27 - Fixing up variable arrays...
DEBUG 2012-02-10 01:39:27 - Done fixing up variable arrays.
DEBUG 2012-02-10 01:39:27 - CHOSEN_INSTALL_SET=Update
DEBUG 2012-02-10 01:39:27 - CHOSEN_INSTALL_FEATURE_LIST=Application
INFO 2012-02-10 01:39:27 - Apache is locally present. Will try to stop it...
DEBUG 2012-02-10 01:39:27 - Checking if web service is running...
DEBUG 2012-02-10 01:39:27 - apache is not using HTTPS.
DEBUG 2012-02-10 01:39:27 - checking URL connection to http://__Fully_Qualified_Machine_Name__:80 ...
DEBUG 2012-02-10 01:39:27 - apache running at http://__Fully_Qualified_Machine_Name__:80
DEBUG 2012-02-10 01:39:27 - apache appears to be up. Shutting it down...
DEBUG 2012-02-10 01:39:27 - PID: 0
DEBUG 2012-02-10 01:39:27 - Apache failed to stop.
DEBUG 2012-02-10 01:39:27 - Installation is Aborting. The installation cannot continue.
FATAL 2012-02-10 01:39:45 - Aborting installation.
FATAL 2012-02-10 01:39:45 - Installation is Aborting. The installation cannot continue.
FATAL 2012-02-10 01:39:45 - Apache failed to stop.: com.ptc.windchill.install.psi.InstallCommandException
FATAL 2012-02-10 01:39:45 - aborting: original exit_code = 2
FATAL 2012-02-10 01:39:45 - aborting: normalized exit_code = 2
DEBUG 2012-02-10 01:39:45 - SHUTDOWN REQUESTED
DEBUG 2012-02-10 01:39:45 - (X) commiting registry
DEBUG 2012-02-10 01:39:45 - (X) shutting down service manager
DEBUG 2012-02-10 01:39:46 - (X) cleaning up temporary directories
DEBUG 2012-02-10 01:39:46 - Exiting with exit code: 2
DEBUG 2012-02-10 01:39:47 - cleanUp()
DEBUG 2012-02-10 01:39:47 - calling cleanUpWin32()
