11-Garnet
January 22, 2014
Windchill 10.1 Info Engine webjects Behavior
  • January 22, 2014
  • 2 replies
  • 1880 views
Hi All,
We are in the process of migrating Windchill 9 customization to Windchill 10.1 . Behavior of Info engine webjects has been changed in Windchill 10.1 .Is there any link or materials which talks about the webject changes in Windhill 10.1.
Example:
In Windchill 9,Query objects complied successfully without type and where tag but,in Windchill 10.1 getting compilation error saying the "TYPE" and "WHERE" parameters must be provided.
You can try to look for any changes in the WHC link of your server. Here is a link from the WHC from ptc.com. The only recent change which happened with 10.2 is the whitelisting of the I*E tasks.
Hope that helps.
Regards
~Syed
  • Hi Do you know how to configure for info engine white listing of Tasks?
I dont' found out in WHC page.
update:
I solve this problem.
<%@page language="java" session="false" access="http" %>
