3-Newcomer
June 15, 2012
windchill 10 workspace size
  • June 15, 2012
  • 2 replies
  • 2478 views
Hi
Is there a limit to the amount of items you can put into one workspace, we have noticed that the larger the workspace the slower it becomes and more java script errors appear. Also with large workspaces windchill 10 will not delete the workspace, you need to go and delete parts from the workspace first to reduce its size, we have a project with 2000 items (.prt/.asm/.drg) how do companys with larger projects cope ?
Best answer by Dinesh_Tondy
  1. Check workspace related best practices at https://www.ptc.com/appserver/cs/view/solution.jsp?n=141290
Have you checked to make sure that objects are actually getting saved?
There is a bug in Pro/E when linked to Windchill where if you set secondary objects to Read Only during the save process, the primary object is not saved.
https://www.ptc.com/appserver/cs/view/spr.jsp?n=2071117
