windchill adapters
  • February 10, 2011
  • 610 views
Has anyone been successful using the windchill adapters to revise and then remove the primary content of a document? I've been able to revise the document using this Revise-Objects webject but unsuccessful in removing the contents using the Delete-ContentItems webject. We are using PDMLink 9.1 M060.
Rey
In delete contentitems webject, what are you passing for content_item,
staging-file_id and staging_area.
If you are not very specific in using I*E webject, you can consider the
following APIs (for deleting the primary doc)
ContentItem myPrimary = ContentHelper.service.getPrimary(document);
if(myPrimary != null)
ContentServerHelper.service.deleteContent((ContentHolder)document,
myPrimary);
HTH
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
