‼Windchill & Creo Direct Drafting‼ Could this be real?
  • June 2, 2014
  • 2 replies
  • 3011 views
The current situation:
ProE Wildfire 4 M200
CoCreate Drafting
Windchill 9.1
The situation after upgrade:
Creo Parametric 2.0
Creo Elements / Direct Drafting (with Workgroup Manager)
Windchill 10.2.
Two simple yes-or-no questions:
1. Does Workgroup Manager acts like a portal between Creo Elements / Direct Drafting (aka CE/DD) and Windchill? (Like PDMLink for Pro/Engineer)
2. Is it possible to sent information from CE/DD to Windchill? (You can show WT.Part attributes in the drawing, can you assign those attributes in the drawing?)
Any help is greatly appreciated.
Best answer by Dan_Harlan
1) Yes
2) Yes, see below, page 163 beginning at "Custom Parameters"
See https://www.ptc.com/view?im_dbkey=157380
1) Yes
You have no idea how much that helped. Thank you!
