Windchill in a Virtual Machine
  • July 19, 2011
  • 4 replies
  • 4406 views
I have retrieved Windchill installed on a virtual machine, and Arbortext Editor is inslatteld in a physical one.
So the virtual machine runs in the same physical machine.
I want integrate Epic with Windchil by modifying the "siteprefs.xml" file in the adapter and put the IP adress of waindchill's machine. but Arbortext Editor can't connect to windchill.
I don't no if someone has already done this configuration.
I'll be greatful if you help me
Cordially
Best answer by RajasekaranPala
As first step, you can remove Arbortext out of picture.
Try to connect from a Browser (from Physical) to VM Windchill and see what happens. (Try only hostname without Windchill context)
If that works then try http://<hostname>/Windchill and during that time if its not coming up, try adding the ip/hostname in you hosts file and see if that helps.
Also, do a IP config in physical/VM and see how the subnet setup is.
I am using Windchill 9.1 and Arbortext Editor 5.4.
the communication between the two machine(virtual and physical) is good, because I have done a ping to verify.
the problem is the communication between arbortex and windchill
Best Regards
1. Physical Machine holds
2. Arbortext
3. Windchill VM
Are you saying 1 can't talk to 3 or 3 can't talk to 1 or both?
I've had problems getting images to talk to their parent physical machines. I'm not a networking guy, but... try an alternate IP and have your router forward to the correct image/physicalbox.
hello everybody,
i have resolve the problem, i've write a documentation wich illustrates steps of the configuration
but this doc is in french, i sorry but my office abligate me to write in french, so if someone can translate it and republishs it i'll be happy
this my email if someone want more informations : -
Cordially
