Mar 5, 2026 2:57 PM UTC
Windchill Install: LAX_VM is not set to Java 21 or later
Version: Windchill 13.1
Use Case: installing windchill
Description:
I am trying to install Windchill 13.1 on Windows Server 2025 Datacenter.
But when I start "solution installer", I get the error message, that "LAX_VM is not set to Java 21 or later".
Amazon corretto JDK 25 is installed.
I found that in this forum https://community.ptc.com/t5/Windchill/Error-installing-Windchill/td-p/926025, which points to this
https://www.ptc.com/en/support/article/CS341598?source=search&_gl=1*wu9ndk*_gcl_au*MjEzNTM5NDc2Ny4xNzcyNzAyODAx*_ga*MTY5OTM5MTYyMy4xNzcyNzAyODAw*_ga_7NMP2MSYPM*czE3NzI3MTc1MzYkbzIkZzEkdDE3NzI3MjIzODMkajYwJGwwJGgw
and this
https://www.ptc.com/en/support/article/CS356999?source=search&_gl=1*wu9ndk*_gcl_au*MjEzNTM5NDc2Ny4xNzcyNzAyODAx*_ga*MTY5OTM5MTYyMy4xNzcyNzAyODAw*_ga_7NMP2MSYPM*czE3NzI3MTc1MzYkbzIkZzEkdDE3NzI3MjIzODMkajYwJGwwJGgw
Unfortunately, none of the solutions provided by ptc work.
Mar 5, 2026 4:10 PM UTC
The "or later" means patches within the Java version, not later Java versions.  Please use the same Java version that Windchill 13.1 supports (21).
Fadel
23-Emerald II
Mar 5, 2026 4:05 PM UTC
Make sure LAX_VM is added to  system variables
Buiꓘa
Mat16-PearlAuthor
Mar 11, 2026 12:25 PM UTC
Thanks! That did the trick.
Mar 6, 2026 7:24 AM UTC
@Mat
The issue is related to your java version. use the version mentioned in the software matrix https://release-advisor.ptc.com/releaseMatrix?releaseId=2272
