May 8, 2025 2:11 PM UTC
Windchill PDM Link SSO solutions
We are looking into implementing SSO for our customer.
Initially we wanted to go with the simpler implementation using Shibboleth As SP and Microsoft Entra as IP.
What other solutions would there be with and would be the complexity level of their implementation?
Alex1988Answer
Feb 23, 2026 3:00 PM UTC
We did a simple implementation with Shibboleth and without pingFederate as in scenario 2 using the basic steps from PTC:
Security Assertion Markup Language (SAML) Authentication
avillanueva
23-Emerald II
May 8, 2025 2:16 PM UTC
What version of Windchill do they have? That might make a difference.
Alex198813-AquamarineAuthor
May 30, 2025 7:07 AM UTC
We have Windchill PDM Link 13.0.2.4. At the moment we went with the simple PTC supported solution with Shibboleth and Microsoft Entra.
It seems to work fine during testing. We would need just to manage the Windchill users like wcadmin or other accounts created.
May 30, 2025 7:22 AM UTC
Are you using ProjectLink with external users? How you configured your workers for SSO as TrustedHost is not supported by PTC. If you can give some insight, that will be great
Best Regards
PR
May 12, 2025 9:51 AM UTC
Take a look at the article https://www.ptc.com/en/support/article/CS314308
Alex198813-AquamarineAuthorAnswer
jbailey
18-Opal
Feb 25, 2026 1:24 AM UTC
If the version of Windchill is 13.0.2 or newer, I would consider OIDC vs SAML if using Entra, especially if they are looking to add OAuth down the road to other tools. If you are using SAML with Entra and need OAuth down the road - you need two Entra entities, one for SAML and one for OAuth. If you use the OIDC apache module (Included 13.0.2.x+) Entra will only need one entity for Windchill. It is a little detail, but minimizes the number of items a customer needs to manage in their Entra IdP. Configuration is straightforward and well documented (I implemented this as a customer before I joined PTC with ease). Additionally, it removes the need to install / maintain / secure additional software (Shibboleth).
