Word document rename question
I renamed a word document in PDMLink 9.1. When I did that the "name" was changed but the 'file name' and "primary content" number did not change. When I download the file the name of the word file, if you were to save it locally, is the same as the "file name" and the "primary content' number. Is there any way to get all of these numbers/names to be the same? I do not understand what replacing the content of these entities does but it sounds as though that may be the cure. I not want to lose the revieion history of the files I need to rename.
John Scranton
