Workflow String Attribute as a dropdown on a Task Form?
  • April 2, 2014
  • 5 replies
  • 1945 views
Is it possible to display a workflow string attribute as a drop down menu? I have a set list of values that I would want to select from?
Check if following helps you.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS36017
April 2, 2014
Septhen,
Please see attached document.Also if you face any issues while creating workflow variable of enumerated type refer below link
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS16646
Hope this helps !!!!
Great thanks for the links. I have a global enumeration already defined. I'm assuming I can't leverage this at all, I need to duplicate the entries in this resource bundle?
Thx,
Steve D.
Hi Stephen,
Shreyas is right,
  1. Set the property file and restart the server as per PTC Document - CS16646.
  2. Create a custom rbInfo file for your LOV
  3. Point your workflow variables by choosing other class referring to your rbInfo class
Hope this will work for your requirement.
BR
MKR
It looks like this is not an option for us as we do not own Windchill Information Modeler and when I try to compile the class I get the following error:
Requires Windchill Information Modeler to compile. 😞
My class:
package <package name=">;
import com.ptc.windchill.annotations.metadata.GenAsEnumeratedType;
@GenAsEnumeratedType
public class WfAttributeLOV extends _WfAttributeLOV {
static final long serialVersionUID = 1;
