22-Sapphire I
Apr 30, 2013 5:18 PM UTC
Workflow template editing
Using Windchill 10.1 M040.
We're seeing on multiple workstation platforms that workflow templates "freeze" such that elements can no longer be edited and the template cannot be saved. This is occuring with IE 8 and IE 9. Seems that it must somehow have to do with our Java installs but we don't know what to look at to troubleshoot.
Has anyone experienced (and solved) this?
note: All workstaions can edit workflow templates in 9.1 with no issues.
Apr 30, 2013 5:33 PM UTC
Hi Mike,
I didn't try 10.1 M040..as we are on 10.1 M030..But I've experienced similar issue that workflow template doesn't open for long time..
And also when opened in view mode...context null errors..and cannot view unless I open in edit..I thought its due to browser/java issue.
But I've experienced difference in behaviour by switching between 64-bit IE browser/ vs 32-bit IE browser and 64-bit Java/32-bit Java.
Please see if you have both 64 and 32-bit java installed..and try with both 64 and 32 bit IE browsers..
regards
Venkata Kotra║Sr.Analyst, Engg Systems ║IS, HHI
Tel : 949-672-4018 | Mobile : 408-771-7739
[cid:image001.gif@01CE458E.26A7B240]
What java version are you using?
Does it work with Chrome or Mozilla?
[cid:image001.gif@01CE458E.2E1A9650]
Steve Vinyard
Senior Solution Architect
Apr 30, 2013 5:34 PM UTC
Also, send over the output of the Java Console. Maybe it is throwing some errors there
[cid:image002.gif@01CE458E.4E97D910]
Steve Vinyard
Apr 30, 2013 5:37 PM UTC
Or this could be an incompatibility between your video card and Java
version.
You can try such things as |-Dsun.java2d.d3d=false| in your Java Plug-In
options if that's the case.
Apr 30, 2013 5:56 PM UTC
Mike,
Using the java control panel, check the box to not store cached copies of
files locally, highly recommend you force java console to show, and that in
the advanced tab, check the options that enable verbose logging details in
console. When the console appears, hit '5' to make it display even more
details. You may get a java stacktrace that clues you in.
If proactively switching between WC releases, recommend leaving the option
to not cache applets on permanently.
If you need screenshots of control panel, let me know.
Dave
20-Turquoise
Apr 30, 2013 8:50 PM UTC
> troubleshoot.
Same problem here with 10.1 M040.
I am running Firefox 17.0.5esr on Solaris and jre 1.6u37.
Like you this setup works on 9.1 M070 with no issues.
I downloaded the latest jre (1.7u21) and pointed my browser java plugin to that.
The workflow templates will now save after editing.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
Apr 30, 2013 8:59 PM UTC
I had the exact same issue on 10.1 M30, and resolved with PTC call.
[cid:image001.png@01CE45BB.AE827830]
Add what Jess informed and re-create the bootstrap classpath by renaming the .wt folder. When JVM is invoked the boot.jar file will be located in the same classpath, and the .wt folder will be re-created.
Yoon (Peter) Kim
281-483-0629
20-Turquoise
Apr 30, 2013 9:18 PM UTC
On 04/30/13 16:08, Lockwood, Mike wrote:
> Attached solved the problem -- need a line per Windchill server for each workstation that needs to edit workflow templates using this approach. Not elegant but ok for now.
And if you want to be able to copy and paste in the applets add this line (in the grant section):
permission java.awt.AWTPermission "accessClipboard";
> *From:*Randy Jones [
> troubleshoot.
> -----End Original Message-----
> Randy Jones
> 1525 E North St
> PO Box 5060
> email:- <
">mailto:->
> Phone: 785-823-3276
> Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Apr 30, 2013 9:37 PM UTC
For those whose video cards don't agree with their Java versions, the
important piece here is the "-Dsun.java2d.d3d=false" portion.
The bootclasspath piece isn't necessary in any recent version of
Windchill -- nor is the other approach of installing boot.jar in your
JRE's lib/ext folder. I think it stopped being necessary in R9.1 M030.
The bootclasspath approach also stopped working with some Java 6 update
or another...
On 4/30/2013 3:59 PM, Kim, Yoon S. {Peter} (JSC-EA2)[Jacobs Technology,
> Regards,
> Yoon (Peter) Kim
> 281-483-0629
Apr 30, 2013 9:41 PM UTC
Hmm.... I assume that's specific to this one applet.
In that case, it sounds like (1) the details of your DNS are tripping up
one of the recent Java security updates and (2) the workflow team likely
needs to do something special to work around this issue.
Jess Holle
