22-Sapphire I
Apr 30, 2013 5:18 PM UTC
Workflow template editing
Using Windchill 10.1 M040.
We're seeing on multiple workstation platforms that workflow templates "freeze" such that elements can no longer be edited and the template cannot be saved. This is occuring with IE 8 and IE 9. Seems that it must somehow have to do with our Java installs but we don't know what to look at to troubleshoot.
Has anyone experienced (and solved) this?
note: All workstaions can edit workflow templates in 9.1 with no issues.
Apr 30, 2013 9:55 PM UTC
I sent Mike an all inclusive .java.policy file. Didn't hear back yet, so
not sure if it was flagged or blocked.
Since we all trust Windchill as not a third party rogue software or malware,
I add the following in a new text file (filename: .java.policy ) (note the
two periods in filename) under C:\Users\<id> for windows 7 (different for
xp/unix)
grant codebase " {
permission java.security.AllPermission;
grant codebase " {
Not granting AllPermission is a IT nightmare, because you have to revisit
everytime an new issue occurs. Better to just exempt trusted servers.
PTC actually should just document this as a technical article as this is not
well documented even by the vendor (Oracle) in a straightforward plan folks'
manner.
I have used this to support all prior JREs for older releases that are
invoked through Java 1.6 and 1.7.
- Dave
Apr 30, 2013 10:03 PM UTC
Forgot to capitalize the 'B' in codebase - so resending.
grant codeBase " {
grant codeBase " {
Apr 30, 2013 10:06 PM UTC
You should not need to add *any* permissions to the JRE.
Having to do so indicates that either (1) you're using an unsupported
Windchill version, (2) you don't have the latest Windchill MOR or
patches or (3) you've managed to find something we've not yet fixed.
Unfortunately given that it sounds like this is occurring for some folk
using 10.1 M040, it would appear that those who have issues with the
workflow applet that are resolved by messing with the java.policy file
are likely experiencing #3 😞
Jess Holle
20-Turquoise
Apr 30, 2013 10:19 PM UTC
The only permission I need to add, to the java policy, is the "allow use of the clipboard" for copy and paste:
permission java.awt.AWTPermission "accessClipboard";
I haven't needed the others.
> Having to do so indicates that either (1) you're using an unsupported Windchill version, (2) you don't have the latest Windchill MOR or patches or (3) you've managed to find something we've not yet fixed.
> Unfortunately given that it sounds like this is occurring for some folk using 10.1 M040, it would appear that those who have issues with the workflow applet that are resolved by messing with the java.policy file are likely experiencing #3 😞
> Jess Holle
> On 4/30/2013 4:55 PM, David DeMay wrote:
>> I sent Mike an all inclusive .java.policy file. Didn't hear back yet, so not sure if it was flagged or blocked.
>> Since we all trust Windchill as not a third party rogue software or malware, I add the following in a new text file (filename: .java.policy ) (note the two periods in filename) under C:\Users\<id> for windows 7 (different for xp/unix)
>> grant codebase " {
>> grant codebase " {
>> Not granting AllPermission is a IT nightmare, because you have to revisit everytime an new issue occurs. Better to just exempt trusted servers.
>> PTC actually should just document this as a technical article as this is not well documented even by the vendor (Oracle) in a straightforward plan folks' manner.
>> I have used this to support all prior JREs for older releases that are invoked through Java 1.6 and 1.7.
>> - Dave
>> *From:*Jess Holle [
>> *From:*Randy Jones [
>> *Subject:* Re: [solutions] - Workflow template editing
>> at to troubleshoot.
>> Same problem here with 10.1 M040.
>> I am running Firefox 17.0.5esr on Solaris and jre 1.6u37.
>> Like you this setup works on 9.1 M070 with no issues.
>> I downloaded the latest jre (1.7u21) and pointed my browser java plugin to that.
>> The workflow templates will now save after editing.
>> -----End Original Message-----
>> Randy Jones
>> Systems Administrator
>> Great Plains Mfg., Inc.
>> 1525 E North St
>> PO Box 5060
>> Salina, KS USA 67401
>> email:- <">mailto:->
>> Phone: 785-823-3276
>> Fax: 785-667-2695
>> Randy Jones
>> 1525 E North St
>> PO Box 5060
>> Phone: 785-823-3276
>> Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Apr 30, 2013 10:24 PM UTC
Yes, because it is signed. I qualify as all three, well four. 3.) Finding
something not fixed, well that'll a long turn around and can't stop working
til then! 4.) Other application required by company using other java
version.
Either way, should still document for all users. For CAD reasons (9.1 M050
production still), you cannot always update to latest MOR since stuff is
inconveniently dropped. And yes, not product to admit, I originally
figured this out because Java 1.6 died on the Windchill 6.2.6 applets. Ka
Boom.
May 1, 2013 2:07 AM UTC
That's covered by a patch and/or recent MORs -- at least all cases I'm
aware of are...
May 1, 2013 1:57 PM UTC
David,
It isn't even Friday yet!!!
Some of my users may disagree with your statement, especially if you define rogue software as anything that slows productivity.
Thank you,
Ben H. Loosli
USEC, INC.
20-Turquoise
May 1, 2013 10:42 PM UTC
On 04/30/13 21:07, Jess Holle wrote:
> That's covered by a patch and/or recent MORs -- at least all cases I'm aware of are...
Jess you are correct. I removed the
entry from my .java.policy file and I can indeed still copy and paste with Windchill applets.
I have tested this (on Solaris 10 x64 client) with the following combinations:
Windchill 9.1 M070
Firefox 17.0.5esr w/Java(TM) Plug-in 1.6.0_37
Firefox 17.0.5esr w/Java Plug-in 1.7.0_21
Windchill 10.1 M040
Apparently I needed the accessClipboard for some non Windchill applets.
So for me editing the workflow templates in Windchill 10.1 M040 does NOT require any .java.policy mods. However it does require me to use jre7. In my case I can't save the workflow after editing it when using jre6 (1.6U37).
>>> Jess Holle
>>>> grant codebase " {
>>>> grant codebase " {
>>>> - Dave
>>>> *From:*Jess Holle [
>>>> at to troubleshoot.
>>>> Randy Jones
>>>> 1525 E North St
>>>> PO Box 5060
>>>> Phone: 785-823-3276
>>>> Fax: 785-667-2695
>>>> Randy Jones
>>>> 1525 E North St
>>>> PO Box 5060
>>>> Phone: 785-823-3276
>>>> Fax: 785-667-2695
>> Randy Jones
>> 1525 E North St
>> PO Box 5060
>> email:-
>> Phone: 785-823-3276
>> Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
Fax: 785-667-2695
