Workspace Undo
  • September 21, 2010
  • 841 views
Gurus,
If you remove an item from workspace, say accidentally because the name
is truncated so you pick the wrong file, is there an undo or a retrieve
deleted somewhere (anywhere) to get that removed file back?
Eric
Wildfire 4.0 Datecode m090
WindChill 9.0 Datecode m030
Potentially...if you have your frames set, and you use your frames right away. You can go into ProE Help and search for Frames, and it will give you all the information you need to manage, adjust and use your frames.
Here is the help information on items that create frames. If you read down a little, you will see that "Removing objects from the workspace" is on the list. Hope this helps. Brian
<h1>About Workspace Operations that Create Frames</h1>
All workspace actions, except refresh, create frames. You cannot create frames for actions that you cannot restore.
The following workspace actions performed in the Windchill connected mode and accessed in the embedded browser of Pro/ENGINEER or using the File menu commands in Pro/ENGINEER create frames:
  • Editing attributes of CAD documents
  • Importing objects in workspace and File > Open in Pro/ENGINEER
  • The addition and deletion of attachments
  • The locking or unlocking of objects in workspace from Actions on the workspace listing page
  • Removing objects from the workspace
  • Creating new CAD documents and new parts using the HTML UI options in the embedded browser of Pro/ENGINEER
  • Save in workspace
  • Check in from active workspace
  • Undo checkout in a specific context
  • Addition of objects to the workspace
  • Update of objects in the workspace and File > Update in Pro/ENGINEER
  • Renaming objects in the workspace
  • The activation of a workspace the first time
  • Apply event
  • File > Save in Pro/ENGINEER
Workspace operations that occur on the server side, such as Modify Attribute, that affect the cache and result in cache change are also recorded as frames. Frames are not created for the following Workspace operations:
  • Set state
  • Associate and disassociate
  • Refresh of the workspace
  • Open in Pro/ENGINEER or ProductView
  • Opening of Information pages
  • Viewing and editing of workspace preferences
  • Accessing the Event Manager or Help
  • Authentication of server registration
  • Creation and locking of the workspace
  • Clear cache from server
  • File export from the workspace
See Also
About Recording Workspace Events as Frames
About the Workspace
About Managing Frames
In Reply to Eric Huffman:
Gurus,
Eric
