WTPart Soft Type Error
All,
I am working on WC 10.0 M020 and I have soft typed the WTPart object to create an Engineering Part. I went through the wizard and successfully created the soft type without error. Then I went into a Product container to create a new OIR for the new object type. I click the Find button to select the object type but the dialog box is empty. I also see the following error in the MS logs. I highlighted lines of interest that I think have to do with the problem but I don't know what the problem is. Any thoughts?
Tue 2/7/12 09:22:38: TP-Processor7: Can't load ESAPI properties from classpath, trying FileIO
Tue 2/7/12 09:22:38: TP-Processor7: The LOG-LEVEL property in the ESAPI properties file is not defined.
Tue 2/7/12 09:22:41: TP-Processor6: ERROR : wt.method.MethodContextMonitor.contexts.servletRequest pwillia5 - 2012-02-07 14:22:39.260 +0000, 2v1dq0;gyd0h5v3;2336;2d7pn;57, -, -, 2v1dq0;gyd0h5v3;2336;2d7pn;56, pwillia5, 10.49.29.43, -, -, , 0, 416, 1.049854638, 0.9204059, 2.30509967
Tue 2/7/12 09:22:41: TP-Processor6: javax.servlet.ServletException: java.lang.ExceptionInInitializerError
Tue 2/7/12 09:22:41: TP-Processor6: at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:865)
Tue 2/7/12 09:22:41: TP-Processor6: at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:794)
Tue 2/7/12 09:22:41: TP-Processor6: at org.apache.jsp.netmarkets.jsp.search.getGlobalTypes_jsp._jspService(getGlobalTypes_jsp.java:79)
Tue 2/7/12 09:22:41: TP-Processor6: at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
Tue 2/7/12 09:22:41: TP-Processor6: at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
Tue 2/7/12 09:22:41: TP-Processor6: Caused by: java.lang.ExceptionInInitializerError
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.windchill.enterprise.picker.type.TypePickerSelectionHelper.buildJsonObject(TypePickerSelectionHelper.java:345)
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.netmarkets.search.utils.GlobalTypesListHelper.writeGlobalTypes(GlobalTypesListHelper.java:89)
Tue 2/7/12 09:22:41: TP-Processor6: at org.apache.jsp.netmarkets.jsp.search.getGlobalTypes_jsp._jspService(getGlobalTypes_jsp.java:72)
Tue 2/7/12 09:22:41: TP-Processor6: ... 41 more
Tue 2/7/12 09:22:41: TP-Processor6: Caused by: java.lang.NullPointerException
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.netmarkets.search.utils.ObjectTypeDisplayNamesCache.getDisplayName(ObjectTypeDisplayNamesCache.java:180)
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.netmarkets.search.utils.ObjectTypeDisplayNamesCache.addTypeToCache(ObjectTypeDisplayNamesCache.java:253)
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.netmarkets.search.utils.ObjectTypeDisplayNamesCache.buildTypeNameCache(ObjectTypeDisplayNamesCache.java:233)
Tue 2/7/12 09:22:41: TP-Processor6: at com.ptc.netmarkets.search.utils.ObjectTypeDisplayNamesCache.<clinit>(ObjectTypeDisplayNamesCache.java:83)
Tue 2/7/12 09:22:41: TP-Processor6: ... 44 more
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image002.jpg@01CCE595.249DF040]
