Jun 20, 2024 12:10 PM UTC
WVS job monitor shows the error is because it is timing out after 900 secs
Version: Windchill 12.0
Use Case: Hello, when i am trying to publish an assembly drawing it is showingthe error is because it is timing out after 900 secs
Description:
when i am trying to publish an assembly drawing it is showingthe error is because it is timing out after 900 secs.
when i open the drawing in creo it regenerates it self everytime which is time consuming. could you please help how to get it published ?
sandy
BenLoosliAnswer
Jun 28, 2024 1:29 PM UTC
You need to make 2 changes.
The first is to increase the timeouts in the recipe file.
The second is to set the publishing times in Windchill with xconfmanager in wvs.properties.
publish.cadtimeout.assembly=7200
publish.cadtimeout.component=600
publish.cadtimeout.drawing=1200
Adjust these times so your largest assemblies and drawings publish.
joe_morton
Jun 21, 2024 5:37 PM UTC
If the assembly takes more than 900 seconds to open and regenerate, you may want to ask your admins to increase the timeout value.
Emeritus
Jun 28, 2024 5:44 AM UTC
Hello @Sandy7,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N
Community Moderation Team.
BenLoosli23-Emerald IIIAnswer
Sandy712-AmethystAuthor
Jan 16, 2025 5:47 AM UTC
thank you for your response guys. @BenLoosli what do these properties means? i mean are they pointing to .ASM, .PRT and .DRW files respectively?
br,
sandeep
avillanueva
23-Emerald II
Jan 16, 2025 12:12 PM UTC
That is correct. Each one has it own timeout. Parts typically do not take a long time. Assemblies can take the longest but there are cases were assembly drawings take a long time too.
