Add dropdown list in activity
Hi Comunity;
I need to bring the fields in the red box below as a list, how can I do this?
HelesicPetr
Hi @smcvr
You need to learn how to use IDE with annotations (Eclipse, NetBeans, InteliJIdea atc...)
"_HataAltSinifi" is autogenerated class by annotations.
PTC Supports Eclipse as a IDE that can be used directly with Windchill.
Windchill PLM - Customization with Eclipse IDE
CS63697: How to install Eclipse IDE for Windchill PLM
Using Eclipse
Example Create Pet Class
PetrH
avillanueva
23-Emerald II
February 28, 2023
My solution was rather complex to this same problem. I was showing a team input as a drop down. Required a custom JSP template and data utility to format the drop down list. Have you tried making the variable something other than text? Possibly a vector or List object?
smcvr15-MoonstoneAuthor
I tried wt.fc.EnumeratedType but no result
HelesicPetr
Hello @smcvr
I did it several years ago, and it is not easy as you can think.
A PTC Article CS36017 describes how to achieve the dropdown list in the task page.
hope this can help.
PetrH
I tried the steps but I'm having trouble adding the java file do you have any information about it?
HelesicPetr
Hi @smcvr
You need to define path to class
the value <path_to_class> is not correct
PetrH
