How to add uploadContent / Attachment to column of custom MVC Table
Version: Windchill 12.0
Use Case:
I have custom MVC table with some pre-defined columns.
I want to add one more column which is uploadContent i.e, it swould be similar to add attachment so that user should able to browse particular file and add it to this table column
Description:
Hello Community,
HelesicPetr
Hi @AKC_301264
Try to analyze following dataUtility
 com.ptc.windchill.enterprise.attachments.dataUtilities.ContentDataUtility
This utility is used in uploading multiple wtDocuments so it can help you I guess
PetrH
Community Moderator
June 14, 2024
Hello @AKC_82440,
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Thanks & Regards,
Vivek N
Community Moderation Team.
Thanks for the reply Vivek. I agree with your points. Below  is the detailed requirement.
I have a custom wizard in which I have implemented a custom MVC table with columns like below
Here, in this table, I want to include new column which is uploadContent so that for each record user should browse and attach a document
Krishna
HelesicPetr
Hi @AKC_301264
PetrH
