11-Garnet
How to listen to event while moving object from one container to another using move action?
hi @BjoernRueegg ,
I have use case while create Part need to move different folder i am using
managerService.addEventListener(partListMoveListener, PersistenceManagerEvent.generateEventKey(PersistenceManagerEvent.POST_STORE));
//for move
wt.folder.FolderHelper.service.changeFolder((wt.folder.FolderEntry) part, folder);
but getting Error ""Cannot move XXXXX because Object "XXXXXX" must be assigned to a folder"". I checked target folder is coming with destination folder.
please help on that
Reference topic: https://community.ptc.com/t5/Windchill-Customization/How-to-listen-to-event-while-moving-object-from-one-container-to/m-p/876767#M1828
@AA_9841156 I haven't tried it while creating a new object. Have you turned the logger on? Perhaps you can't listen to the event since it is not a move while creating a new part. Also, you need to make sure that a later event won't override your made changes.
wt.services.verbose=true
wt.services.verboseEvents=true
Since it is a new WTPart it could be that you can set the context and folder within the NEW_VERSION  event. See also CS164007
Just my thoughts.
18-Opal
Hi @AA_9841156,
Is there any reason not to set the target folder using OIR?
Why do you want to use Listeners?
11-Garnet
Hi @TDT ,
Actually  i have to move part once created, to related service container . but for time being i just checked same container but different folder.
18-Opal
Hmmm,
I just wrote a listener to detect a move. Upon move I print a message to state what got moved and to where.
It's works as expected.
MS LOG reads:
2025-06-19 08:05:15,761 INFO [ajp-nio-127.0.0.1-8010-exec-7] wt.system.out wcadmin -
2025-06-19 08:05:15,761 INFO [ajp-nio-127.0.0.1-8010-exec-7] wt.system.out wcadmin - You just moved Document - 0000000028, Testing, A.2 to /Default/Testing/Testing. Now what?
And then I move it back to its original folder.
MS LOG now reads:
2025-06-19 08:45:23,460 INFO [ajp-nio-127.0.0.1-8010-exec-7] wt.system.out wcadmin -
2025-06-19 08:45:23,460 INFO [ajp-nio-127.0.0.1-8010-exec-7] wt.system.out wcadmin - You just moved Document - 0000000028, Testing, A.2 to /Default/Documents/Testing. Now what?
It works as expected. Not sure what you want to do upon move, you never stated that 🤷‍♂️, but the listener definitely works.
11-Garnet
Hi @d_graham @BjoernRueegg
Actually my requirement is if Part or PartList created so as per OIR that object will be store mentioned folder as mentioned in OIR. once object  created I want to move that object to respective service container to different folder.
that use case i am trying with Listener POST_STORE event but not able to do it.
18-Opal
So, OIR has nothing to do with this.
You just want to move the part somewhere after it’s created. Very doable but how do you know which container/folder to move the part to? 🤷‍♂️
What’s the logic you are using to determine the new location?
Just my thoughts.
11-Garnet
Thanks @BjoernRueegg  for sharing your thoughts and this thoughts hit the solution super.. 😊
Its working as per expectation.
