7-Bedrock
Multiselect Data utility for multivalued attributes
Version: Windchill 13.0
Use Case: Using the + sign on multi-valued attributes with enumeration or pick list is an awful UX design. Has anyone built a data utility or interface JSP to populate using drop down checklist or a multi-select check list (like the type manager has).
Description:
when selecting multiple values for an attribute, there is a + (plus) sign to add another row to pick more values.   All other interfaces in the world (including type selection in the search ) us pull-down checkboxes, or pick list
has anyone already built the customization to do this that can be easily plugged in.  (Hopefully would be universal to handle any attribute)
Emeritus
Hi @DM_01_9885362,
Thank you for your question.
Vivek N
Community Moderation Team.
Also looking for this exact thing.
Has a solution been found for this yet?
I’m currently facing the same problem.
