8-Gravel
August 2, 2024
Update EPMDocument IBA through JAVA
  • August 2, 2024
  • 3 replies
  • 1275 views
Good evening,
I'm having trouble understanding the process of updating an IBA of an EPMDocument.
I'm trying as it follows:
attributes.put(attributeName, attributeValue);
PersistableAdapter epmObj = new PersistableAdapter(epmDoc, null, null, new UpdateOperationIdentifier());
epmObj.load(attributeName);
epmObj.set(attributeName, attributeValue);
EPMDocument obj = (EPMDocument) epmObj.apply();
PersistenceHelper.manager.modify(obj);
However I didn't get any changes on the attribute itself. I'm guessing that in this case I need to checkout the EPM and do the changes on a working copy of it to persist the changes.
However reading the documentation and other topics I haven't found a clear flow to check-out--> set the attribute and then check-in the object. Can someone give me a hand on this if possible? Thank you kindly for your support
Best answer by GrahamV
You are correct, you need to check out the object first, make the modifications, then check in. I think you need something like the below...
doc = (EPMDocument) WorkInProgressHelper.service.checkout(doc, WorkInProgressHelper.service.getCheckoutFolder(), null).getWorkingCopy();
PersistableAdapter pa = new PersistableAdapter(doc, null, Locale.getDefault(), null);
pa.load(attributeName);
pa.set(attributeName, attributeValue);
doc = (EPMDocument) pa.apply();
doc = (EPMDocument) PersistenceHelper.manager.modify(doc);
doc = (EPMDocument) WorkInProgressHelper.service.checkin(doc, "IBA Updated");
Graham
Community Moderator
August 6, 2024
Hi @AK_10639313,
Thank you for your question.
Vivek N
Community Moderation Team.
GrahamV12-AmethystAnswer
Graham
Community Moderator
August 12, 2024
Hello @AK_10639313
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
