Feb 22, 2024 8:31 AM UTC
How to implement Single Sign on for Thingworx (navigate )on azure
Hello All,
I want to implement SSO on Thingworx(navigate) on Azure Cloud. How should I do that and what are the necessary things I need to configure and where to configure, and all details I need. Any documentation which explain  clearly other than PTC docs.
KSM
sderooseAnswer
May 3, 2024 7:26 AM UTC
Hello KSM,
as of Navigate 9.5 Azure AD is also supported and documented. See
help center
Was a bit tricky to configure the Windchill side as well.
best regards,
Stijn
Feb 22, 2024 9:39 AM UTC
Take a look:
KSM15-MoonstoneAuthor
Mar 1, 2024 3:39 AM UTC
Hi Vladimir,
Thanks for reply,
The link you have provided that shows the configuration of SSO through Ping federate, I need how to configure SSO on AD Azure. and also tell me is PingFederate mandatory for the configuration of SSO.
KSM
sderoose13-AquamarineAnswer
Hello KSM,
help center
best regards,
Stijn
