Sep 8, 2015 4:46 PM UTC
Part II Enhancements on Windows Explorer Integration for Windchill Desktop Integration 10.2
In my last blog post Productivity Enhancements on Windows Explorer Integration for Windchill Desktop Integration 10.2, Part I I discussed the possibilities and enhancements around the Windchill Documents system folder in the Windows Explorer.
This blog will show you how easy it is to display Windchill Meta data information in the Windows Explorer Integration.
I will also discuss the integrated Windchill search and how leverage the Windchill Index Search functionality.
View Windchill Information
Windchill metadata information of your documents can be displayed in the Windows Explorer without opening a browser to access the Windchill web application. Even applying filters is possible.
To do so, you have to navigate from the Windchill Documents node to the context that you are interested. On the right hand pane you will see the stored documents.
You may add or remove attributes by right-clicking a Windows Explorer column heading to see a drop down menu of additional columns available.
Is the attribute still not available in the out of the box list?
No problem, since Windchill 10.2 F000 you can select Windchill folder views to add columns that appear in the list. With Windchill 10.2 M010 even the filters on these views will affect the data displayed in the object list.
This allows you to configure which documents will be show in the folder. E.g. if you only want to display the latest document version, then apply filter settings on the Windchill table view (in the Set Filter step select Revision and Version attributes and set them to Latest).
Folder Search for Windows Explorer
All the features that I showed until now required that you exactly know where the documents are located in your Windchill system but this unfortunately is not always the case. While manual navigating through the folder structure is cumbersome and annoying to find a document, there is a simpler way to find your documents.
Starting in Windchill PDM Link 10.2 F000 you can search for any Windchill document using the Windchill Search action. This is a quick and easy way to search for your documents inside of the Windows Explorer Integration without the need to open the Windchill web application.
The search can be initiated from context, container or folder level within the Windchill Documents node. This will allow you to search by Name or Number on this context level and all sub-contexts.
Please note that the search is case-insensitive and wildcards are allowed. Add asterisk (*) as a wildcard character to indicate that one or more characters can appear in that position.
For Windchill systems with Index Search enabled, even document content will be taken into account when calculating the results if the option “Include search within content (only if index search is enabled)” is selected.
The native Windows Explorer search field (in the top right corner of the Windows Explorer) can also be used to perform a search but this will yield slightly different results. The search will only be performed on the current folder / context and not on any sub-context.
In case you are also interested in the location of document in the folder structure, you can use the right mouse button menu to select “Open File Location”. This will open the Windchill context or folder in which the object is stored.
Conclusion
This was the last part of my post about productivity enhancements on Windows Explorer Integration.
I hope that you liked this brief tour on the Windows Explorer Integration if you are interested in more details, you’ll find further information in the Windchill Help Center.
Thank you also for your many comments on part I.
As always let me and the community here about your thoughts and questions:
  • What do you like about the Windows Explorer Integration and what do you think is missing?
  • In which scenarios you are using the Windchill Explorer Integration?
bsaupp12-AmethystAuthor
Sep 25, 2015 4:21 PM UTC
Hello Chris,
sorry also to you for my late response here because of the same reason that I crashed my system.
But on the other hand I have good news to you about the IBAs.
So when you add the IBA to the table view you will get the information displayed without the need of any configuration. This is done the following way:
  1. Create or edit a table view in Windchill's web application and add the IBA that you want to make available (some restrictions apply but I will come to this later)
  2. Use the right mouse button menu on the Product / Project / Library... nodes in the Explorer Integration and select Windchill Views to select your costumed view
  3. If you now open the Product folder your either already have the attribute column visible or you have to add it like mentioned in the above blog post.
This is how the result looks like:
But as mentioned there is one single restriction:
Alias and calculated attributes will show up in the available columns in Windows Explorer but they will not show values. This is because of the DTI not supporting alias and calculated attributes. Product management is aware of this.
When it comes to displaying structures:
As you maybe remember this already came up during my last blog post and you may be remembering Scott Morris‌ answer to one comment that there had been internal discussions about how structures could be represented without breaking the UX.
But as you all share some good perspective on the need and requirements that you have I will definitely make Product Management aware of your comments to my blog posts.
Hope this answers your questions.
Kind regards,
Björn
7-Bedrock
Oct 26, 2015 9:32 AM UTC
Hello Björn,
Thanks for a nice post. I have a question that is maybe slightly of topic.
We have a customer that is using DTI, mainly in office but also the explorer integration.
They do however have performance/stability issues
- It can take several seconds for the context menu to open in explorer.
- Open a document in word fail first time, a blank documents opens instead of the actual document requested. Second attempt works.
I have a gut feeling that it is related to the fact that they are working in a high latency (~350ms) environment, even if they do have a replica for the content files.
Do you know if there are any possibility to improve this? Any settings/preferences available?
Anders
Oct 26, 2015 10:15 PM UTC
You can also move documents between folders/contexts using drag-and-drop. The trick is to hold down the Shift key:
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/DTIExplorerDragDrop.html
Oct 26, 2015 10:23 PM UTC
By "context menu" I'm assuming you mean the right-click menu in Windows? If they only ever use the right-click Windchill menu when working under the Windchill Documents node in explorer, they can turn it off the rest of the time using the "Windchill Context Menu for Windows Explorer" configuration option.
They might also tinker with some of the other options in the configuration menu: http://support.ptc.com/cs/help/windchill_hc/wc102_hc/DTIServersManage.html
However, it sounds like this might end up as a Tech Support call.
