Absolute accuracy set when creating from new file from Empty?
All,
Two fold question.
Is there a way to change the default of Relative accuracy (something that PTC has moved away from) when creating a new part in Creo Parametric from Empty?
(We do use templates, but if a User does an import to Empty and does not run ModelCHECK, we can be in danger)
If there a way to remove Empty option when creating a new part from Creo Parametric?
I already know PTC's answer, but didn't know if someone found a customization.
