Activation of modeling within an assembly
  • October 13, 2016
  • 6 replies
  • 2386 views
Hi all,
when you are within an assembly and you want to model a part, you can edit a single dimension or activate the part. In this case also the icons change and show you the part environment.
Here I have two problems:
1) if you show the datum planes/axes/points, also the planes/axes/points of the assebly are shown, creating a much confusion if the assembly is big;
2) you can't see where the part is in the model tree if it is inside a sub assembly. It would be nice if the model tree could open at the point of the activated part.
Are there some options in the config.pro or something else?
Bye
Best answer by kdirth
I am using CREO 2.
Try this thread:
MCAD Central
kdirth
1) Your datums and such need to be on layers for each part and assembly.  You can then hide all of the layers in the layer tree.  When you want to unhide layers for one part, select the arrow at the top of the layer tree then the part and only the layers for that part will be shown.  You can now unhide only the layers for that part.
2) To find the part, before you activate it, select the part, right click and select "Locate in Model Tree" and the tree will expand and move it into view.
gfraulini17-PeridotAuthor
Thanks Kevin.
I answer for points:
1) this way, in my opinion, is very slow, but I admit that it works.
2) I use WF5 and I don't see "locate in model tree". Maybe you use a Creo release where this feature is already implemented?
kdirth
kdirth21-Topaz IAnswer
I am using CREO 2.
Try this thread:
MCAD Central
