Add Parameter to Parameter
  • August 5, 2019
  • 4 replies
  • 1704 views
All,
I feel I have done this before.
How do I add parameters to a parameter?
I have parameter "title_1". It is assigned the name "washer". I would like to add ID OD & THK parameters on end.
For example washer, .265 ID X .500 OD X .032 THK.
Maybe too early for me. Can this be done?
Wayne
Creo 4.0
Best answer by jbob
create a parameter called description, then write a relation something like this
description = ID + "ID" + "X" + OD + "OD" + "X" + THK + "THK"
this may seem a bit confusing because you will have parameters called ID, OD, & THK and you want to add
text after the parameters.
jbob12-AmethystAnswer
wfalco16-PearlAuthor
DOH..a relation. Yeah - it's early. Thanks jBob!
Wayne
KenFarley
Hey Wayne,
Here's an old discussion of this kind of stuff...
Parameters to Text Discussion
Lots of detail, but should get the job done for you.
