Adding Datum targets to a mirror merged assembly
  • July 21, 2015
  • 4 replies
  • 2063 views
Having an issue trying to add ‘targeted datums’ (planes) onto a merged mirror part. We typically do parts (Sheet metal) them pull them into assemblies where we add our PEMs & such. I have a left & right part. The right is the master, and the left is a mirror merged part. Each have their own assembly (with pems 7 such) and each ahev their own drawing.  And, erach have their own dwg number, etc...
I managed to add datums to various surfaces in order to create GTOLs in the drawing with the original part. Now, when I try to create the same datums on the mirrored assembly (assembly with the mirror merged part) I cannot get the same datums. I can make datums, but they insist on being ‘ATSMXX’ or some other name I want to give it. I would like to give them the same datum identifiers as the original parts as detailed in the drawing, to keep consistency between the left & right parts.  But, when I try to label the datum as the corresponding datum, it says "Invalid, name in use".  And, I cannot seem to pull them up, assuming they are in use on the original model / part.
So, what is causing this conflict, and how can I get to use the same label on the corresponding datums? Is it an issue with the mirror merged part in the assembly?
Any help or insight is appreciated!
paul
Best answer by StephenW
We get this same problem with merge and inheritance parts we do. The work around is to temporarily rename your original datum in your original part, then create and name your mirror merge part datum. Then go back to your original and rename it back.  Sounds crazy but it works.
StephenW
StephenW23-Emerald IIIAnswer
Thanks Stephen, it worked.  But I guess I shouldn't be surprised as to how to accomplish it...
A bit of a go-around to open, save, close, open, save, close, clean memory, open, rename, save close re-do GTOLs....
I see mirroring parts as more of a hassle downstream, than the time it saves up front..
StephenW
You don't have to erase memory, you can just rename the datum, add the new one to the mirror part and then rename the old one back. Seems extra silly, I can't justify it, it just works.
