All of the windows for inclusion in the template must be from the same study directory (Error Message)
Good Day All,
I have run into this message in the past and have not thought much of it till now.
Running a simple assembly containing 3 parts in Creo Parametric Simulate. I have 4 results windows up on the screen for the same assembly obtained from a design study that ran 4 separate load cases in the design study. When I try to save the display as a template I get the following error message...
"All of the windows for inclusion in the template must be from the same study directory"
It appears that you are not able to create templates for multiple results windows being driven from a design study with multiple load cases.
Verified in Creo 2 and in Creo 3 M030
I think I'm missing something simple here?
Thanks for any insight you can shed on this,
Don Anderson
