ampersand(&) in relations window.
  • September 28, 2017
  • 2134 views
I'm working with an existing assembly file and I have observed that they have used '&' before the dimension in a relation.
Ex: &d340:1 = FLANGE_WIDTH      (Here FLANGE_WIDTH is a parameter).
I want to know the use of '&' here, because I observed it works without ampersand in a different assembly file.
Best answer by dschenken
"&" is used in drawing notes to distinguish text from parameters. Someone probably carried this over and Creo obviously ignores it. There's no interpretation I see for it when used as a prefix in a model relation.
Using a "$" does have a significance to indicate the sign of the value is important. The default is to use keep the value positive and switch the direction of a related dimension.
dschenken1-VisitorAnswer
