Assign Name and Color to a surface
  • October 17, 2015
  • 2209 views
In Creo Parametric 3.0 is it possible to select a surface and give it a name and color/transparency value? for example, suppose i create a box by extrusion and then i want to select one surface of that box and call it say "Inlet" and assign a green color and possibly a translucency. is that possible?
thanks
Best answer by swarsi
thanks to PTC support they said the following :
Yes. Creo will allow you to assign a name to a surface using UI picks File > Prepare > Model Properties > Select ‘Names’ , select a surface and then type in the name you want to assign to it.
Just for everyones information.
swarsi1-VisitorAuthorAnswer
