Dale_Rosema
Assmbly cut - thread still showing in removed material
  • November 10, 2014
  • 4 replies
  • 2159 views
An assembly cut is being made on one end of a part. That end of the part had two tapped holes. Now that the material has been removed, the threads are still showing (suspended in air). Shouldn't they be gone?
Thanks, Dale
Best answer by TomD.inPDX
Nope, those are solid cuts.
Have a look at this workaround on the drawing:
Hide cosmetics in drwhttp://communities.ptc.com/message/261764#261764
Dale_Rosema
... but if the threads aren't there, then why are there cosmetic threads?
The solid holes aren't there but solid cuts don't affect the cosmetic surfaces.
