auto update revision block table
  • April 16, 2018
  • 7 replies
  • 8945 views
I have been creating drawings with multiple sheets and would like a faster way to update my revision block. Is there a way to update sheet 1 revision block and have it auto-populate to sheets 2 thru last sheet? I saw a "copy_cell" configuration for Creo 2.0 M130 and earlier versions but I have Creo 2.0 M160. Any ideas on if this is even achievable and if so, how?
Similar to this link:
https://community.ptc.com/t5/Creo-Modeling-Questions/Dynamic-Auto-Revision-Table/m-p/83745#M21216
Still not solved.
Best answer by dgschaefer
I've investigated this in the past and found that the effort to automate it and ensure that it always worked as expected wasn't worth it.  My solution was to put revision info on only the first sheet and place a note in the "rev block" of later sheets indicating that all rev info is on sheet one.  Having it only in one place is simpler than trying to make sure that every place is identical.
Another method is to update the rev table on sheet 1, select the table, cntrl C to copy it to the clipboard, going to sheet 2 and deleting the rev block there and then paste the sheet 1 table using coordinates to ensure it's in the proper position.  If you do that every time it's changed it'll always be identical.  You probably could automate much of it with a mapkey.
Dale_Rosema
Are you using Windchill or not?
If you are not using Windchill, you could add a parameter to parts/assemblies (i.e. rev_lev) and assign it to the part/assembly. In your title block you call the parameter and it will update/propagate throughout the sheets when you update that parameter on the model. At least that is how we do it. There may be better ways out there.
Dale_Rosema
I was talking about revision level. As for following pages, I just have a title block. Revisions are on Page 1.
The only good way to get table information to automatically update is to tie it to parameters - either model parameters or drawing parameters.  Then anytime you update one of these linked cells it will automatically update everywhere else that parameter value is displayed.
If you want to stay with "dumb text" in the table cells then I would suggest using something like SmartAssembly.  You could pretty easily write a little program to copy the table contents from one sheet to another.  (I'm sure you could do this with the VB API or J-Link as well but programing is not nearly as simple.)
dmaynard1-VisitorAuthor
That is usually what I do but was hoping for something faster.
Thank you
StephenW
The easiest way I've used is to have a parameter in the drawings (maybe drw_rev) and set that parameter as the revision. Then have your format call out &drw_rev:d on each sheet.
