Blend edge to surfaces
- November 13, 2013
- 13 replies
- 27759 views
I am looking for suggestions on how to blend tangent from a variable radius to a non-planar edge. The perfect command would be something like "blend edge to surfaces". Sort of like the "blend section to surfaces" command, but to an non-planar edge or curve instead of a planar section . Any ideas? Pictures and step file are attached. The yellow lines show where the surface would be in 4 locations. Thanks.
Tom U.
Tom U.
