BOM Exporting
  • February 2, 2010
  • 1365 views
Does it possible to export the Bill of Material of an assembly into an Excel file instead of HTML? P.S.: My ProE version is WF2.0 Thanks to all
Try Config option: info_output_format (set to text) then save the file as a text file. Then you can open using Excel and set columns as "Fixed Width". It's not perfect, but it gets it into something you can work with.
