Bom Repeat Index in a Note
  • September 24, 2019
  • 2 replies
  • 1752 views
All,
Not sure if it's do-able. Can I make a note that reads:
1. Remove burrs from f/n (item) 3.
And have the "3" report from the bom?
From what I've been reading the answer is or was NO?
Hopefully I am explaining properly?
Creo 4.
WayneF
Best answer by StephenW
In this duplicate idea, @mender explains that there is a certain amount of difficulty in doing this within the software
 https://community.ptc.com/t5/Creo-Parametric-Ideas/Repeat-index-parameter-value-as-by-rpt-index-for-example-in-a/idi-p/454250
StephenW
I don't believe you can use repeat region parameters (rpt.index) outside of the table and balloons.
It sure would be nice and...
https://community.ptc.com/t5/Creo-Parametric-Ideas/Refer-to-rpt-index-in-a-note-or-symbol/idi-p/462296
StephenW
StephenW23-Emerald IIIAnswer
