Build model on wrong datum plane, How do i change it
  • April 15, 2016
  • 5 replies
  • 7294 views
I'm just learning this software and realized I that I built my model on the wrong datum plane, it is now upside down, is there a way to just reassign them or do I need to restart the sketch over again on the correct plane?
Best answer by AmitDeshpande
If you selected the incorrect sketching plane, you can change it within Sketcher from the Sketch Setup.
This will open up the following window, where you can replace or remove and add a new sketching plane:
Amit
re-setup your sketch
get to where you are editing your sketch and in the upper left on the ribbon, there should be an icon "Sketch Setup"
18-Opal
April 15, 2016
Amit
bbrejcha
I teach both the above method + Edit References  or what was Reroute.   Anyone try Edit references?
Bart Brejcha
Design-engine.com
Bart Brejecha designengine.com
18-Opal
April 26, 2016
If either mine or Ron's answer helped, please mark it as the Correct Answer.
Amit
will do, thanks, your method worked great, sorry would of responded sooner, I was busy
