Can I manually enter in the center of gravity of a part
  • March 8, 2013
  • 8 replies
  • 6680 views
Is there a way to manually enter in where the center of gravity is on an assembly (based on X, Y, Z coordinates, possibly)?? I'm using a STP file of a motor and want to manually place to COG since I don't know what the materials are of each part to find out their mass properties. I'm in the process of finding out what the actual COG is from a vendor but want to put this into my model so I can see how it affects the overall COG for the assembly that the motor is attached to. Thanks.
Best answer by jsarkar
Yes u can do it, for creo do to file>prepare>model properties> mass properties> in the top of the window select geometry and parameter and place you predefined value.
Jayanta Sarkar
jsarkar1-VisitorAnswer
Jayanta Sarkar
That worked perfectly. Thanks.
Dale_Rosema
Don't forget to mark it as correct for those who follow behind.
