Can IFX create assembly cuts?
  • October 31, 2017
  • 2 replies
  • 3042 views
Normally, when you create a hole (using Hole) at the assembly level, it creates an assembly cut - the hole feature is not propogated to the part, so when you open the part by itself, it will not have a hole. Is there an option that allows IFX to duplicate this functionality?
Best answer by OliverGräbner
Could you please mark this as solved.
You can set the following values for HOLE_VISIBILITY
Default is PRT.
SELECT—Select hole visibility.
PRT—Create hole in part.
ASM—Create hole in assembly.
NO—Do not create a hole.
Never mind. I found the HOLE_VISIBILITY option
OliverGräbner
Default is PRT.
Oliver Gräbner - B&W Software GmbH
