can you relate custom symbols to notes in creo 2.0?
  • March 1, 2017
  • 13 replies
  • 5835 views
    Best answer by svillafuerte
    Here is an old mapkey we used to use in our config file that would do this back in Creo 2:
    mapkey ro @MAPKEY_NAMERelate Object;@MAPKEY_LABELRelate Object;\
    mapkey(continued) #TOOLS@DRAWING;#RELATE OBJ;#ADD ITEMS;
    Save it in your config file and type ro to run it. Or if nothing else you can see the picks it needed to get to the relate object feature.
    Hope this helps.
    Chris3
    You might have to be clearer about what you mean by relate.
    You can embed symbols into notes: &sym(symbol_name) - although for Creo 2 not for 3D notes: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS69664
    dcoleman1-VisitorAuthor
    I mean, before in previous versions of CREO, you could "relate to text" or "relate to view" to attach custom symbols such as rev. triangles, etc. I you "relate to view", it moves with the view, but if the text moves around, you have to pick the symbols and move them to the new note location for appearance sake. Time consuming if you use a lot of custom symbols to designate "significant product characteristic" or other.
    Doris,
    I'm not sure about Creo2, but in Creo3 you can use "Relate to Object" to do what you want. It is in Drawing>Sketch>Group.
    Hope this helps.
    Tim
    This is also referred to as Offset placement in the symbol instance dialog.
    Hope this helps.
    Thanks, that's it!! Wish I had this 200 drawings & 1000 symbols ago
