Cannot Remove Surface From Drawing
  • June 15, 2017
  • 6 replies
  • 5900 views
I have imported a parasolid, which contains some inserts that have been interpreted as surfaces. An issue arises when I come to make the drawing. The inserts are permanently shown in every orientation. The below image shows what it looks like (this is not a section view) and I have tried the normal method of erasing the line using Edge Display but no cooperation from creo.
As this is a parasolid, it is all imported as a singular item so am unable to delete the individual faces/bodies.
Is there anything I am not thinking of?
Cheers,
Nick
Best answer by tgriffin
Switch over to your layer tree.
Create a new layer.
Add the surfaces to your new layer (it might help to utilize your selection filter).
Then hide the new layer, and save the layer status.
You can set it so those surfaces are hidden in your layer tree.  If there is not already a layer for them, just create a layer with the surfaces on it and then hide that layer and save the display status.
nhall12-AmethystAuthor
Although it is acting like a surface, my model tree only contains an imported feature so no surfaces are actually selectable.
tgriffin1-VisitorAnswer
Create a new layer.
