2-Explorer
October 17, 2015
Change Default BOM
  • October 17, 2015
  • 2 replies
  • 1552 views
I would like to change default BOM one can add from Table-->Quick Tables-->All Tables --> BOM Description Down.
By default, Column sequence is ITEM NO, PART NUMBER, QTY , DESCRITPION and NOTES. I would like to interchange column no of ITEM NO with QTY.
Could any one suggest where to replace which file so that I can have updated BOM table once I do Table-->Quick Tables-->All Tables --> BOM Description Down?
Regards
Ketan
Best answer by Ronan
Hello Ketan,
you should modify the initial table and save it in the CREO Folder (C:\...\Creo 3.0\M060\Common Files\text\table\)
to change a parameter in a repet region, double clic in the region and navigate through the menu and sub menu. When you do not have the 3 points (...), you come to the end of a parameter!
in your case,
for Qty, you should navigate like this: rpt...qty   and obtain rpt.qty on the symbol.
for Item NO, you should have: rpt.index
hope that helps
Ron
Ronan14-AlexandriteAnswer
Hello Ketan,
in your case,
hope that helps
Ron
2-Explorer
October 19, 2015
Thank you very much. I am able to find initial table in installation directory of creo as suggested by you.
