7-Bedrock
July 17, 2019
Changing default tolerance from "ansi" to "DIN/ISO"
  • July 17, 2019
  • 2123 views
i am using Creo Parametric 6.0 and changed some settings in the configuration editor.
But at one point i am struggeling to change it to default. I wanted to change the geometry tolerance from "ansi" to DIN in the config file.
After that i saved it added it back and restarted but it is still on "ansi" when i open the part preparations where i can select materials etc.
But on the configurations it says it is DIN. Does anyone know why and how to solve this?
Best answer by kdirth
I don't have 6.0, but changing the config file will not affect the part files.  You will need to change it in each individual file (good job for a mapkey) and to have it set for all new files your start parts will also need to be updated.
kdirth
kdirth21-Topaz IAnswer
