2-Explorer
September 22, 2015
Create a PDF
  • September 22, 2015
  • 2 replies
  • 1784 views
im wondering how to publish to a PDF, so it pops up the PDF, before i have to save it.  in intralink, the pdf would show up on the screen, then do a file save as, and name it.  this one wants me to name it before i create it.  i dont really want to do that.  i would rather have the pdf show up, then look it over before i save it.
thanks
Best answer by RonSt.Pierre
Try this mapkey "caf".  Created in Creo2.  Just add to your local config.pro
If you need this for WF, let me know.  there is a little difference.
I do a couple things before I create the pdf.  I first turn the datums off (d-), then I zoom-reset (zr) the window.
I also supplied my .dop file for Adobe. Place that in your work or "start in" directory.
If it doesn't work, use yours (adjust code below - "bad1pdf" with yours). Adjust it as you see fit.
mapkey d- @MAPKEY_NAMESwitch off all datum display options;\
mapkey(continued) @MAPKEY_LABEL>Datum display off;\
mapkey(continued) ~ Activate `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh396938342.proe_win|.mcs29658718_mp|select_\
mapkey(continued) all_check` 0;
mapkey zr @MAPKEY_NAMEZoom reset;@MAPKEY_LABEL>Zoom reset;\
~ Command `ProCmdViewRefit`;
mapkey caf @MAPKEY_NAMEMakes a .pdf file and stores\nit in your work \
mapkey(continued) directory;@MAPKEY_LABEL>Create Adobe File;%d-;%zr;\
~ Command `ProCmdModelMkPdf';\
~ Select `intf_profile` `opt_profile`1  `bad1pdf`;\
~ Activate `intf_profile` `OkPshBtn`;
Mahesh_Sharma
22-Sapphire I
October 20, 2015
Daniel,
Does the information in Ron's reply answer your query? You may mark that reply as correct answer fro the post.
