Creating a user parameter that is linked to a model or system parameter
  • July 14, 2017
  • 7 replies
  • 4506 views
I ahve a Start part that is used every time I create a New Part.
I have created a user parameter in my Start Part named PART_NO.  It is a String type of parameter.
I would like to know how I can associate this user parameter to the the name of the part.
For example if I create a new Part using the above mentioned Start Part and name it TEST1, I would like the User Parameter from the Start PArt, which is named PART_NO, to have the value of TEST1, which is the name of the new part I just created.
Hopefully this makes sense.
Any suggestions?
Best answer by BenLoosli
Create a relation in your start part that evaluates the model name to your parameter.
Part_no = rel_model_name
This will take the model name and assign it to your Part_no parameter.
BenLoosli23-Emerald IIIAnswer
jforsyth14-AlexandriteAuthor
Thanks.
That worked!
We use that all the time so there isn't any confusioin downstream cause by the user naming the file one thing and then putting in text for Part_no parameter in your example parameter. If you are using Windchill here is another parameter and relation that we are starting to use.
TITLE = PTC_COMMON_NAME
In the title block of the drawing you can then set that cell to use word wrap.
