Creo 2.0 Shell Computing/Frozen
  • December 21, 2015
  • 5 replies
  • 3167 views
Hello Everyone,
Is there a way I can "abort" from a command?
I'm currently waiting for Creo 2.0 to calculate a shell feature on a part.
The task manager says the 4 cores are operating at about 8-12% power.  I've been sitting here for about 45 minutes.
If I kill Creo in the Task Manager, I might need about 2 hours to redesign the part I was working on, but I'm not sure if Creo will finish computing anytime soon.
Help, please?
Best answer by MartinHanak
try clicking STOP button located in the botton right corner of graphic window.
MH
I am running Creo Essentials.
I'm not using Creo Simulate.
I am simply trying to shell a solid and Creo seems to take hours to complete the task.
Why are you asking about Creo Simulate?
I can't upload the model due to confidentiality.
I'm not concerned about making the shell feature work.
I want to find a way to abort the command when Creo gets stuck calculating the feature.
Is there a keyboard input which causes Creo to stop what it is doing aside from closing the software via the task manager?
